It sounds a little tappety, but no where near as bad as my bike was when I first got it!Ponch1972 wrote:Let me know if you think it sounds okish?
Check the valve clearances and the side float on the rockers (it's adjustable).
If the bike has only been used occasionally then the rocker bushes/shafts may be worn. That's why I advise using 10w40 Semi synth, it tends to cling better. New rocker shafts can easily be made from 12mm silver steel (just a couple of circlip grooves), I made new rocker bushes from bronze, but NLM got hold of some originals a while back.
The rocker tips also wear so you end up measuring the valve clearance PLUS the tip wear. I reprofile the rocker tips with a diamond lap although you could use a very narrow feeler gauge or gauge wire.
