Black 9 1/2
Black 9 1/2
Does anyone know anything about the 9 1/2 for sale at Portsmouth? Thanks
Re: Black 9 1/2
Seems cheap & appears to have just obtained an MOT, I'd buy it for spares just in case but already have too many bikes. Carmo should be able to sort out the non displaying clocks too. Let us know if you go for it.
Re: Black 9 1/2
I have put a deposit on it. But haven’t arranged pickup yet
Re: Black 9 1/2
Great, let us know how you get on with it
Re: Black 9 1/2
Seeing as I've just lost the Speedo on my scrambler & checking on here, seems like Speedo sensor failure is quite common
but that said could be an easy fix
Re: Black 9 1/2
They should be quite a common sensor and not too expensive
Re: Black 9 1/2
I fitted a Ducati one to my Corsaro, but years ago so don't ask the part number!
Re: Black 9 1/2
Could it be the same as this? Ebay(NEW GENUINE DUCATI SUPERBIKE 848 / 1098 / 1198 SPEEDOMETER SENSOR 55240372E)
Re: Black 9 1/2
Couldn't say. I took mine to the Du, Duc, Duca,, local emporium for people who like electrical problems and they found one with the correct plug.
It was over a decade ago!
Re: Black 9 1/2
I bought a 1098 sensor for my Corsaro. Same other than the cable being longer which is obviously not a problem.
Re: Black 9 1/2
Think they are pretty generic bar the cable length & fitting - looks similar to the one on my Guzzi 1200 sport
Re: Black 9 1/2
Speed sensor failed on my scrambler so I bought "NEW GENUINE DUCATI 749 BIPOSTO 2003-2006 SPEEDOMETER SENSOR 55240373A" from ultimate parts worldwide on eBay for just under £70 - apart from the cable being a bit longer it arrived next day & seems to work fine.
