sump plug
dougi
sump plug
Post by dougi »
can anyone give me the thread sizes, diameter and thread pitch for the sump plug on a 1978 3 1/2 sport engine. on modern jap bike you can get magnetic sump plugs. so if i have thread sizes i can use one from a jap bike :idea:
mgill
Post by mgill »
Or glue a magnet to your plug....
MRC #2795
dougi
Post by dougi »
thanks i thought of that, but which glue ? the glue needs to handle the heat and vibration while the engine is running and i need to know how hot the engine gets to pick a glue ! :?
corsaro chris
Post by corsaro chris »
The original Harglo service manual says that the sump plug is 18mm :)
I got some neodymium magnets from a firm called Cermag last year-nickel plated ones as it is corroded quite easily. I have araldited one under the sump plug, though it might have stayed put without. Didn't fancy it sticking onto the chain.
Anyhow I have so far not collected any manhole covers or scaffolding as I pass.They are about the diameter of the end of the sump plug and around 8mm thick. Put 2 together if you dare.You can get them apart with extreme effort and caution or you will get blood blisters as they snap together.Quite brittle too.
I should weigh the plug /residue to see if there is any increase but I have not.
I got 10 for about a tenner. If you want I can send one up. You will find the postman attached to the letterbox.
dougi
Post by dougi »
today i changed the engine oil and my 3-1/2 the sump plug size is 22mm dia X1.5 mm thread pitch and 18 mm spanner size !!
mgill
Post by mgill »
Let us know if you find something that fits.
I'm about to drill mine for lock wire and if I bung it up
I'll need a new one!
MRC #2795
dougi
Post by dougi »
i found this one but its in US dollars which makes it expensive to ship to the uk.
we need M22 x 1.5mm thread pitch
order Number--- 1016 SM---
http://www.magneticdrainplugs.com/metric.htm
My sump plug looks more like the type shown as 1025 or 1009, though as it is in situ I cannot check the size.
