Progressive springs
unreal
Progressive springs
Post by unreal »
Hi all,
I have replaced the forks springs on my '82 Strada with a progressive pair from NLM (Hagons), they feel like they need some pre-load. I wa s wondering if any one has an idea as to what size spacer I should start with? I have found a set of adjustable pre-load spacers for Marzocchis which go from 20-70mm, a good plan?
Simon
Daddy Dom
Re: Progressive springs
Post by Daddy Dom »
I didn't use any with my new springs but am keen to hear any other users' advice.
Dom
mgelder
Post by mgelder »
What they said.
The front fork sag with you sat on the bike, feet on the pegs, should be around 1/3 of the total travel.
unreal
Post by unreal »
Thanks for the help.
I ended up with 5mm spacers and it feel about right.
The biggest problem I've been facing is stiction which I tracked down to the replacement mudguard bridge, all was ok without it but binding when tightened, a little persuasion with a mallet seems to has eased thing up!
Simon
