Steering Lock & Seat Lock
I have the ignition key but it doesn't fit the steering lock or the seat lock. Are they usually operated by different keys? Is it possible to determine the key reqd or do I need to purchase (if available!) new locks? Presumably the only way of removing the locks is to drill out the fixing rivet.
Nick
Nick
Was about to drill out the rivet on the steering lock as prep for replacing the lock when I realised that the business end (the blade) of the key was still in the lock. With a lot of WD40 and a sewing machine needle, I managed to extract the broken off blade.
I don't think it is viable to weld a new bow (the bit you use to turn the key)onto this.
Have spoken with my local locksmith but he needs to know the name and code on the bow to get the correct blank. Can someone please supply me with this information? A photo too would be great. The same information for the seat lock key would also be appreciated.
Thanks guys
Nick
Thanks guys
Nick
Well...here is a link to a BMW one, which I reckon looks identical.
http://www.motorworks.co.uk/bmw/product ... g&spPage=2
- George 350
I can confirm my steering lock is also made in Germany by Neiman, but it has no numbers on it.
The fuel cap key is made by FAAB in Bologna and googling that brought up this website http://www.morlands.demon.co.uk/index.htm
They may be able to supply a blank.
Re: Steering Lock & Seat Lock
Just to update the steering lock thing:I have removed my steering lock just now as I lost the key when my fob fell apart on the road.It is 39 mm in total length. I think the BMW type is 46mm in length so probably will not fit.
I bought a steering lock for my strada from Motorworks and it fits OK.
David
Re:
My local Timpsons were able to go through the rack and cut a Datsun key blank to fit a Triumph (car) lock.ringer wrote:Have spoken with my local locksmith but he needs to know the name and code on the bow to get the correct blank.
Or even, dare I mention it, from a Vespa parts supplier.
