One more remark: i used the bike in may for the last time (dutch morini club 25 years) and everthing was ok (except a little delay on 3000, but the engine didnt stop)
Here with a visitor from the UK
What i did today:
Tested with the carbs and the balancetubes : hanging at 3000 rpm for 4-6 seconds and dying (if i try to increase the the rpm at the carb(1/4 -1/2 turn)- the revs are going up to 6000 and very very slowly coming down till 1200- impossible to drive
Tested with balancetubes only :hanging at 3000 rpm for 2-3 seconds and dying.((if i try to increase the the rpm at the carb- the revs are hanging 6-8 seconds)
Raised the petroltank a little to look if there was some air in the tubes.
Then i got an overflow of the right carb---Strange-- (not the first time,had it in may after filling the tank)
Then i decided to take the carbs of the "new" Dart --- seemed a little bit better hanging 3-4 seconds and then 1000 rpm , most off the time it keeps running -- but i could not increase to 1200
Around 6000rpm in second gear it seems like it didnt got enough petrol (or to much ?), was shaking and needed several seconds to get to 8000-NOT GOOD
Oh yes , i attached vacummeters and both carbs are syncronised
So far for the carbs
Tomorrow i'll mount the originals again (i have checked the Float assembly and could not find anything special, blowing in the petroltube and moved the float up - then it was closed.)
They looked like new inside and there is a 107 main jet
Renewed 1 o-ring on the choke (little bit damaged)
On my first bike there is a tiny hole (1mm) in the rubbers on the airfilterside.Why ? No idea
Today i tested with the new ones
About the ignition.
I have 2 marks on the flywheel 50 and 35.(50 is 5mm more to the left)
Checked with a strob and the 50 mark was inline with the centre off the cam-shaft
Changed it to the 35 mark- no change in behaviour off the bike.
Not sure what the right position is for a 400 engine- the 35 or the 50.
What i noticed ,i from 3000 up, there is only a very little change in timing.
Selling new bikes with this behaviour is a crime - GRRRR Cagiva
