3½ Racers...
Re: 3½ Racers...
Hi
Does anyone know how to identify this cam?
Neil
Neil
Re: 3½ Racers...
This seems to be the most comprehensive info on the Camshaft choices. As Mr. Compton noted above,Does anyone know how to identify this cam?
there is some discrepancy over the L5.
http://www.motomoriniclub.nl/tabel.html#cams
Mathew
MRC #2795
Re: 3½ Racers...
Sorry this threads been dormant for a while...
I've got an L5 Cam on the way from 3D in Germany.
Anyone have experience carburetting the L5II in a 3 1/2?
Mathew
Mathew
MRC #2795
Re: 3½ Racers...
Time for an update I suppose...
Thanks to all of you who have emailed me with advice.
First race was June 5,6. The bike is still together....
Against the CB500/550's Rd400's et al placed 4th.
Against the GPZ 550's TZ250's etc placed 6th.
Not bad considering I had no mid throttle (too rich on the atomisers)
Front cylinder needed rings (still standard bore) when I went to torque the rocker arms
back on, two studs pulled out(!!!) Waiting on an M8 time sert kit to fix.
Decided to run the stock airbox (instead of the pod filters) and now need to re-wire the whole bike...
...again.
Race two is in Quebec July 10/11
Hope you're all out and riding.
Mathew
...again.
Mathew
MRC #2795
Re: 3½ Racers...
Hi Mathew,
Good to hear your 3 1/2 is up and running, send some photo's I'm sure we would all like to see it.
Re: 3½ Racers...
MRC #2795
- Sam Stoney
Re: 3½ Racers...
Man, that exhaust has gotta be loud!
