500 Left side main bearing
Maestro, SEI-V
Cactus
Post by Cactus »
The saga continues, can anyone recommend a supplier of a left hand side main bearing please?
'It must be a .....'
Re: 500 Left side main bearing
I'm certain it's no longer available from SKF?
Search this forum for information on alternative solutions
eg viewtopic.php?p=33057#p33057
Good luck in the quest and let us know how you get on, Ian
Post by simonnorthroad »
I have at least one. I'm in Bath. PM me. I'm keeping one back for my 500/5
I think my 501 has a modified main bearing. I have receipts for this but am currently many miles from home so cannot confirm. The original has an ID of 33 mm which is rare or extinct in the wild.
If you can get that one so much the better.
Otherwise and if I understand the situation options are
Get a replacement 33mmid bearing.
Get a modification to accept a 30mm ID bearing.
Get a bearing as above then get the vintage bearing co to modify it.
Cactus
Post by Cactus »
simonnorthroad wrote: 25 Dec 2024 10:04 I have at least one. I'm in Bath. PM me. I'm keeping one back for my 500/5
Thanks simonnorthroad, I’ve managed to get one from Mdina Italia
Cactus
Post by Cactus »
Cactus wrote: 30 Dec 2024 14:56 Thanks
Well, at least it’s ordered!
Cactus
Post by Cactus »
Wellll, I’ve got a new left side main bearing from MDina Italia which apparently is a modern replacement for the original. After having the new bearing pressed into the crankcases the next problem has arisen. The crankshaft, which I believe should just ‘slip in’ doesn’t. A few gentle taps don’t help! Help, any suggestions?
What is the OD of the crank journal
What is the ID of the bearing
I suspect there is a 3mm difference
Cactus
Post by Cactus »
I will be getting them measured at an engineering place in the next day or so ( I don’t have the tools for this) but a rough measurement wth a vernier gauge indicates a difference of about .25 of a mm.
OK- what are the numbers on your new bearing?
Accirding to my invoices mine looks to have been modified to accept a readily available size bearing, if/when it sees daylight I will know.
It says 240111Mod on the receipt in my file.
Cactus
Post by Cactus »
Yep, thats the one thats in it.
That is interesting . I’ll revisit my folder in case there is mention of either bearing or crank modification.
