The bike runs great until the battery dies, no DC charge getting to the battery through the regulator. I have converted the ignition to a Sasche system and it works very well, in addition I had the stator rewound by Westcounty Windings in the UK two years ago.
Since the original Ducati Electronics ignition was abandoned I did not have the ignition coil rewound. I have two wires coming from the rewound stator, with the engine running at idle, attaching a multi-meter at AC scale to the two wires I read 19.5 volts at idle, at 4000 RPM this climbs near 45 volts and at 5000 rpm I am reading 55 ~ 60 volts AC. Based upon these readings I assume the stator is functioning as it should??
I have reviewed the factory shop manual wiring diagram for the early and later 500 bikes and I believe I should be following the early diagram showing two wires from the stator to the reg/rec, a brown wire form switched fuse box to reg/rec and ground the body of the reg/rec to frame.
I have tried two Ducati Energia reg/rec units, both stamped 343142, and have terminals G G R+B C, I am connecting the two yellow stator wires to G and G and the brown to fuse box to C. Body of reg/rec ground to frame. I read online that the terminals marked R+B are not wired to the regulator circuit and are not used in this application. In this configuration neither reg/rec is putting out any DC voltage, regardless of engine rpm.
I also have a reg/rec that came with the motorcycle when I purchased it, there are no manufacturers marks on the cast body but there are fixed wires coming from the body, Yellow - Green - White - Red - Yellow. I connected the two stator wires to the two yellow reg/rec wires and the red wire from the reg/rec to battery positive, the green wire had an eyelet terminal so I assume this is ground, no idea what the white wire out of the reg/rec is for. I get no DC voltage readings out of this reg/rec unit.
I can find very little online to test the function of a reg/rec other than a mulit-meter on diode testing the G G terminals to the cast body with no readings present.
Am I missing something very basic or could all three reg/rec units be faulty????
Can I fit any single phase reg/rec unit to this motorcycle? I see several affordable single phase 12V reg/rec units on Ebay.
