Leaking Clutch Oil Seal
Hi, I hope some of you can please help here.
I recently fitted a new clutch casing, using Paul Compton's excellent YouTube videos as a guide. I don't have a 'sleeve' to help fit the main clutch oil seal, so I just used plenty of silicone grease instead. Result, oil leakage from behind the clutch (I did use hylomar on the hub bush).
So, to try to fix it, I removed the 'new but leaking' seal externally and replaced it. The clutch basket dowels presented no problem when reassembling. However, it still leaks but not so much. Very frustrating!
I'd appreciate any comments as follows:
1. Is it realistic to expect to fit a new clutch seal without removing the clutch casing, and being oil tight as a result?
2. Do you really need to use a sleeve when you refit the clutch basket into the seal?
My dream is an oil tight clutch... thanks for any feedback!
Re: Leaking Clutch Oil Seal
Do you mean the small seal or the large seal?
You can use an old yogurt pot cut up as a sleeve.
I would remove the whole casing and start again. I had a problem with the crankshaft seal, using the ones in the kit from NLM. I bought a good quality one and resolved the leak.
Don't forget the little tube to the oil pump!
Thanks Mickey, yes I do mean the large clutch seal. I was hoping to change it without removing the entire clutch casing, not sure now whether this is possible?
'It must be a .....'
I've always removed the whole primary casing
On a BMW bevel drive box I once replaced a large seal by punching two holes in the seal with a hardened/sharp nail, then screwed in self tapping screws and easily removed the seal with two pairs of pliers. It's important to punch rather drill the holes.
Might be worth trying?
Let us know how you get on
Thanks for the feedback. In fact, I have already removed the old seal externally without removing the clutch casing, but having replaced it, it still leaks.
The question is, is it technically possible to replace this seal without removing the clutch casing? I'm interested to know if anyone has successfully done this?
Surely the clutch basket goes through the seal and screws to the clutch end of the primary drive? How would you remove the seal, unless you unscrew the basket from the drive gear?
Easier to remove the whole casing, in my opinion.
You can easily unscrew the clutch basket to separate it from the primary drive gear, thus exposing the oil seal for easy access.
terrys31/2
Hi Jonny P,
Did you manage to cure the oil leak/clutch slip, as i have the same problem on my 31/2
Hi Terry, sorry for the late reply. No, I haven't yet solved the leak, but I'm planning to remove the clutch casing again soon. I'll be using double lipped seals from Simply Bearings, which are excellent quality. Hopefully this will be the last time!
Sorry about the late reply and update to this. I decided to remove the clutch casing and primary drive, and replaced all seals including the main seal. I took great care to fit the new main clutch seal (a quality, double lipped Viton type) before refitting the casing assembly with primary drive already bolted to the clutch basket.
The latest is that now, a few weeks later, there is still the smallest evidence of a leak from this seal after a run, despite all the care I have taken
To be fair, there's only about as much oil dripped out as would cover a 1p coin on the garage floor, and it stops fully after a couple of hours. Maybe it's impossible to have a clutch seal that never leaks!
Wear on the shaft where it runs in the seal?JonnyP wrote: ↑09 Sep 2023 19:43 Sorry about the late reply and update to this. I decided to remove the clutch casing and primary drive, and replaced all seals including the main seal. I took great care to fit the new main clutch seal (a quality, double lipped Viton type) before refitting the casing assembly with primary drive already bolted to the clutch basket.
The latest is that now, a few weeks later, there is still the smallest evidence of a leak from this seal after a run, despite all the care I have takenTo be fair, there's only about as much oil dripped out as would cover a 1p coin on the garage floor, and it stops fully after a couple of hours. Maybe it's impossible to have a clutch seal that never leaks!
A little light 'misting' aids a smooth clutch take up in my experience - though that's with WeeVee's clutch spring assisters (washers under the spring cups) to be fair.
Gilera: 1957 175 Sport
Honda: 1984 CB250RS
Wishlist: 2026 Morini 350
Honda: 1984 CB250RS
I would as 72degrees says take a look at the bearing face of the clutch outer basket that runs in the seal may be it has some wear or grooves. Another possibility is that the bush in the primary drive which allows the primary drive gear to rotate on the sleeve when the the clutch is disengaged, i.e lever pulled in, is worn thus allowing the whole basket to wobble.72degrees wrote: ↑10 Sep 2023 17:08Wear on the shaft where it runs in the seal?JonnyP wrote: ↑09 Sep 2023 19:43 Sorry about the late reply and update to this. I decided to remove the clutch casing and primary drive, and replaced all seals including the main seal. I took great care to fit the new main clutch seal (a quality, double lipped Viton type) before refitting the casing assembly with primary drive already bolted to the clutch basket.
A little oil seems to actually not be a bad thing anyway.
There is even a little drain notch in the outer case.
Thanks guys for your valuable insight. It perhaps doesn't help that I have a PVC tiled garage floor in pale grey, that I keep very clean...every last speck of oil shows up - ah well!
Newspaper? Drip Tray? If you owned an old British heap it wouldn't stay clean for long.
Just done my garage floor with Leyland floor paint. Covered it with a rug and some foam.
terrys31/2
Hi Jonny, I am on the same journey as you were, trying to tackle the clutch oil leak.
Did the double lip oil seal behind the basket help? and have you any advice ?
