Rev Counter / Ignition switch 1975 Strada
Cooklets
Post by Cooklets »
Hi Everyone!
I am after an electronic rev counter for a 1975 Strada. Also, the big nut that fits around the ignition switch barrel. Your price paid!
Mike Cook
mbmm350s
Re: Rev Counter / Ignition switch 1975 Strada
Post by mbmm350s »
Hi Mike
There are different nuts for the switch Depending on the exact switch and key. I don't have a chrome one but i have black one with hole 16mm and the rubber seal. It depends on the key shape whether it will work. Can you post a picture of the key.
Cooklets
Post by Cooklets »
Hi Mark
I can't find the key at present, but the hole in the nut is 22 mm. Any help?
mbmm350s
Post by mbmm350s »
Hi Mike
Sorry I couldn't load the image,
If your switch has a shutter which closes the lock when key is removed then it uses nut with larger central hole and there is no seal.
Pattern parts come with a plastic nut which isn't strong enough.
Originally they were brass - chrome plated or black.
can you email to mbmm350s@gmail.com
Cooklets
Post by Cooklets »
Email sent!
