Side panel badges
Maestro, SEI-V
Steve48
Side panel badges
Post by Steve48 »
Hi, can anyone advise please how to safely remove and later re-place these badges. I need to re-spray one panel.
Re: Side panel badges
Are they held by the clips or has someone added some gunk to hold them?
If just the clips, then you can pull the clips off, but I always break at least one of the 'pins'.
So I would be interested, too...
If you still have the clips and the pins are intact, then, cut them off and use new ones.
Steve48
Post by Steve48 »
Thanks for the replies. All pins and clips are in place. There is also a round plastic blob in the middle of the four pins, don't know if this is important. Sounds tricky, guess I will have to give it a go.
Steve
Steve48
Post by Steve48 »
Success, I sprayed the clips with WD40 and later, I was able to lift the tabs on the clips with a small screwdriver and off they came. The badge just popped off all pins intact. The plastic blob doesn't do anything.
Steve
That's good - the badges are as expensive to replace as many other parts! (Well, almost...)
