I'd look into what transducers you're using before you start talking about rev limits/limiters.
If you can find a copy of Vic Willoughby's 'Classic motorcycle engines' (or similar title - its a large format book, yellow cover) when talking to Lambertini he mentions that the transducers back-off the timing at peak revs. I did an article about it many ATGs ago, so browse your back copies and you should find it.
As such trying to get your revs up on standard units is a bit sub-optimal. If you're using something after market I'd go for 8,500-9,000. I've had my non-501 500 round to those figures easy. It's still together. In truth you probably don't need a rev limiter as the valves start floating around those revs anyway
Pete
