Corsaro ignition
Clive
Corsaro ignition
Post by Clive »
Hi.
Can anyone help me? I searched for info on any service info for a 1970's Corsaro 125, but with no success.
I'm looking specifically at the ignition - points gap and timing.
I've found various info on valve clearances - .05mm and .10mm.
Any info at all would be great.
Thanks.
Clive
SettebelloDoug
Re: Corsaro ignition
Post by SettebelloDoug »
Hi Clive
I have a 125 Corsaro data sheet, but I have to say that it is undated. But it probably answers your questions. It shows:
Ignition gap: 0.35 to 0.40mm. Ignition timing 37 to 39 degrees before top dead centre on full advance.
Valve clearances inlet and exhaust: 0.05mm.
Hope this helps.
Doug
Clive
Post by Clive »
Hi Doug.
That helps a lot. Many thanks.
Clive
Tom
Post by Tom »
http://www.rpw.it/Documentazione.htm
then scroll down to our maker, voila!
Tom
