Does anybody have, or know of a source for new bigend shells for the 500?
My 501 rebuild has come to a halt as I can't get new shells! I managed to find a brand new crank and the unobtainable main bearing (Thanks Hermy!), but no bigend shells.
Being a new crank I need standard size shells, although if oversize shells turn out to be the only option then I guess I'll have to sacrifice a crank life.
I work for MAHLE so am in the process of seeing if they can help, but knowing if there are any other engines with the same size shells would be a good starting point.
I had my conrods measured on the CMM at work- 38.1mm housing, which is 1.5". Why on earth would Morini have used a 1.5 inch bigend shell (on a 35mm journal)
Bigend shells
Re: Bigend shells
Because they were made in the US by Federal Mogul probably.morini_tom wrote:I had my conrods measured on the CMM at work- 38.1mm housing, which is 1.5". Why on earth would Morini have used a 1.5 inch bigend shell (on a 35mm journal)
