Work is only 1 mile away so leisurely little journey there this morning, especially as the front brake will need some bedding in (new pads and 26yrs of rust on disk) but all ok.
Warmed her up properly after finishing at lunch to see if she will tick over off choke ok (eventually yes), then decided to put some gentle miles on it this afternoon in the sun.
Called in at a friends house a couple of miles away to show her off when i noticed a growing oil puddle underneath. Rode even more gently (in 4th or 5th at 30mph) back home again - damn lucky I had stopped at his rather than the long journey I had planned.
Got back ok and started to investigate. It appeared to be from RHS of engine, off with rh cover and it would appear to be coming out of my crank seal behind the cambelt pulley/generator.
Bugger.
Now how difficult a job of replacement is this? from the manuals i have it isnt clear if the seals go in from the outside or inside....
Will I also have to consider the oil relief valve needing investigation?
Again, bugger, as once warmed up the initial feelings of riding it were starting to fulfill my 25 year odd wait to own one
as you can see the oil is around/below the crankseal
overall views of the 'finished' article
