350 tank and panels please
I'm pretty flexible on condition, although the better the better if you see what i mean!?
Re: 350 tank and panels please
Which year or style are you looking for?
I have a late style tank from a K series bike (slips over spigots on the frame at the front, rather than bolted on).
I also have a perfect pair of Shapecraft early rounded side panels. See this link..
viewtopic.php?f=5&t=8068
sheddweller
Hello Morini Jen,
I am in need of an early Strada fuel tank , but they seem very rare. I might be interested in adapting your K tank.
I live in Queensland ,Australia. Postcode 4554. Would you be prepared to pack and post it to me, obviously at my prepaid expense?
If so, could you post/send some phots and price.
Garry Roberts
Garry Roberts
Hi Garry.
In theory I would be willing to sell you the K tank and send it to Australia. I appreciate that spares are hard to find where you are, but it would be good for me to be sure that you know how much work may be needed to adapt your frame to accept the tank.
As you probably know, the front of the K tank slips over two spigots on the frame with a rubber buffer in between. At the rear of the tank a nut and bolt go through a bracket on the frame, again with a rubber buffer and bush. Of course you may be a highly skilled and fearless welder/fabricator in which case I shouldn't worry. I shall post some pictures of the mounts on the frame for you to look at and assess.
As for the tank itself. Well it needs paint and badges but there are no discernable dings or dents. You will see in the photos that there is some surface rust but I'm sure it will clean up without any major work. The inside of the tank is clean and rust free as far as I can see.
Price-wise I would be looking for £150 with P&P on top. I have absolutely no idea how much it would cost to send to Australia but we can sort that out as or when the time comes.
In an ideal world, someone may read this thread and offer you an early tank. If that does happen, or if you decide that the K tank will need too much work, that would be fine. It will still be for sale to anyone else, at £150 plus P&P, or free collection in Warwickshire.
Here are the photos...
- K Tank front mount.jpg (210.35 KiB) Viewed 165 times
- K Tank rear mount.jpg (213.79 KiB) Viewed 165 times
- K Tank 01.jpg (189.7 KiB) Viewed 165 times
- K Tank 02.jpg (200.94 KiB) Viewed 165 times
- K Tank 03.jpg (208.19 KiB) Viewed 165 times
- K Tank 04.jpg (218.12 KiB) Viewed 165 times
- K Tank 05.jpg (186.03 KiB) Viewed 164 times
- K Tank 06.jpg (200.73 KiB) Viewed 164 times
- K Tank 07.jpg (215.14 KiB) Viewed 164 times
- K Tank 08.jpg (145.48 KiB) Viewed 164 times
- K Tank 09.jpg (136.43 KiB) Viewed 164 times
- K Tank 10.jpg (122.02 KiB) Viewed 164 times
- K Tank 11.jpg (138.14 KiB) Viewed 164 times
- K Tank 12.jpg (175.61 KiB) Viewed 164 times
- K Tank 13.jpg (166.75 KiB) Viewed 164 times
A bit off topic, but can you fit those rubbers to an old frame and use this type of tank? The rubbers appear to be the same as on later bikes (Excalibur, Kanguro etc), so it could be an easy fit.
The rubbers will be needed to mount a K tank. The issue is the position of the front spigots and the need for a bracket at the rear of the tank. It can be done, but it needs some skill.
See photos for comparison...
- K Tank front mount cr.jpg (153.69 KiB) Viewed 70 times
- 350 Early frame detail.jpg (106.81 KiB) Viewed 70 times
- K Tank rear mount cr.jpg (147.08 KiB) Viewed 70 times
Thanks Jen, the front mounts are a bit more to the rear, but this can be done with a fitting like on the before mentioned Excalibur, the one I have was actually fitted to one of those, believe it or not (see pic). On the rear you can just fix it with a rubber band and some rubber underneath I think.
