Has anyone else had a problem with the carburetors shaking excessively? To the point that the tend to flood?
I have fitted rubber inlet tracts from NLM to my '76 Strada and they seem to be too soft, allowing a lot of movement.
The carbs have been balanced and the problem seems to be worse on the front cylinder, especially at idle.
Any ideas? Ron
Carburetors
Re: Carburetors
Have you got the normal rubber trunks from the airbox to the carbs? They help to hold everything in the right place.
"I'll have a V please, Bob."
Re: Carburetors
Unfortunately the NLM ones are too soft, I had two split in short order, Stuart replaced them no questions asked.
I got a pair from "Start Gomma", google it, different animals, no trouble since.
deslandes3074
Re: Carburetors
Thank you, I have just ordered the new rubbers from STARTGOMMA (plus a few other bits and pieces -178 Euro) Not cheap, but worth it if they fix the problem.
Cheers!
Cheers!
