Evening all,
Is the correct chain for the 3 1/2 Sport a 530 with 96 links?
I found a reference to the chain for the Strada on the Dutch website but wondered if the Sport was the same since it has a bigger back hub.
Any input gratefully received,
Nick
3 1/2 Sport chain
If you're replacing sprockets you could go down to a 520 chain, the 530 is overkill. Then you have the option of a 520 O-ring. Some people have fitted 530 0-ring chains, but you can end up with case damage.
Sprockets unlimited can supply most Morini sprockets.
