3 1/2 Sport chain
moolfreet
3 1/2 Sport chain
Post by moolfreet »
Evening all,
Is the correct chain for the 3 1/2 Sport a 530 with 96 links?
I found a reference to the chain for the Strada on the Dutch website but wondered if the Sport was the same since it has a bigger back hub.
Any input gratefully received,
Nick
mgill
Post by mgill »
Yes that's correct. Should be the same size. 14x38 sprockets 96 links of 530 chain.
MRC #2795
If you're replacing sprockets you could go down to a 520 chain, the 530 is overkill. Then you have the option of a 520 O-ring. Some people have fitted 530 0-ring chains, but you can end up with case damage.
Sprockets unlimited can supply most Morini sprockets.
moolfreet
Post by moolfreet »
Thanks for the info.
I'll look into some new sprockets too.
Nick
mantaray
Post by mantaray »
and O-rings will cost you some HP
