QD de-cat
power commander
water proof bits and bobs
set up static sag on the bouncy bits
repalce a few bolts with stainless items..
I've got the standard cat off..... weighs a tonne, doesn't look like it'd see may years of year round riding before it rots to bits. standard system is very well bolted together though, the lambada sensor was a bit of a pig to get out( will remember to copperslip everything). Space for the power commander will be tight however once i've worked it all out and how to route things for max space i'll post up some pics.
A few questions.... has anyone got any suggestions for useful things to do before I bolt it back together?
I've got a velcoe with ohlins rear, can you adjust the preload on the shock with it fitted in place, not the remote but the adjuster on the shock body which will raise ride height? it all looks very very tight
when I do get it all sorted i'll post up pics and results of the dyno set-up, might be a short while though as working is taking up all of my time.
