350 K2 Brake Pads
Posted: 26 Dec 2025 03:35
by KiwiChris
I’m soon to be recommissioning a 1984 350 K2 that’s been in storage for 11 or so years. I’ve got most of the stuff in hand that I’ll need but I am struggling with tracking down new brake pads. The calipers are the standard Grimeca units. From the pictures received, they look to be using the two pin type brake pad. Discs themselves are the standard chrome plated, drilled and will need a good clean up. Mdina don’t have stock. I have 3 questions for the hive mind.
1. Recommended supplier for Grimeca pads
2. Good alternate make of pads
3. The preferred compound for use on chromed discs
Thanks in advance for your help.
Re: 350 K2 Brake Pads
Posted: 05 Jan 2026 02:04
by Daddy Dom
If you didn't find this thread yet, have a look here.
viewtopic.php?t=5705
I think I also have some packaging from old sets that may help with ref.numbers.
Dom
Posted: 12 Jan 2026 02:38
by KiwiChris
Hi Dom, thanks for the info. Very helpful. I’ll see if the supplier mentioned is still on business, if so, I’ll be ordering up new pads F&R. Thanks again. Are you by chance an IMOC member?
