Water pumps can be a bit noisy on Corsaros but I think mine is noisier than it was. Still functioning fine but keen to investigate before I have a problem.
Has anyone replaced the pump or bearings in the past? The manual talks about inspecting the impeller but no mention of any bearings and seals. Unless an impeller came loose on the shaft I can’t see how it would result in noise, and if it was loose then it wouldn’t be cooling properly.
By the looks of it to get to any bearings you’d have to remove the whole right hand side cover which means oil drain and possibly the pump drive gears coming out as well as new crankcase gaskets- seems like a whole load of work which would be nice to avoid unless strictly needed…
Waterpump
Re: Waterpump
I know what you mean about them being noisy and yes sometimes they are noisier than other times. I put it down to cavitation and find that next time it'll be alright again.
Re: Waterpump
Tom, the waterpump shaft is also carrying the sprockets of the cam chains. Any noise coming from the cam chains will be lead via the shaft to the waterpump - like a loudspeaker.
So first, I would check the cam chain tensioners, sometimes they stuck.
Depending on the cam chain you use (small DID, wide DID, Borg Warner) I can imagine, that different noise levels are generated.
Ebi
Ebi
Re: Waterpump
Interesting comment regarding the camchain noise transmission- I hadn’t thought of that.
My bike is a first series so originally had the smaller chains. It recently had the camchains and gears replaced (TR1613050) so it could be that the later type parts make more noise.
It’s hibernating for the winter now but I’ll check the tensioners too when the opportunity arises
Re: Waterpump
I had engines with the original small DID and the actual Borg Warner 98XRH2015 of the TR1613050 kit , the small DID is less noisy and has 45% less strength
