125H/Corsaro
Lambertini era singles (125 and 250 - half v-twins)
125H
125H/Corsaro
Post by 125H »
does anyone know if a Corsaro exhaust pipe would fit a 125H/
Re: 125H/Corsaro
Post by Morini Jen »
Hi Leonard.
It seems unlikely as the Corsaro exhaust exits forwards and between the frame downtubes. The 125H exhaust exits on the side and outboard of the frame downtubes.
Having said that, if you like, I could do some measurements of a Corsaro pipe tomorrow to see if it may be possible to use part of it to fashion a new down pipe. I've probably got a spare one available.
Jenny.
Parker3865
Re: 125H/Corsaro
Post by Parker3865 »
A 125 is half a 250 2c. could you modify a 250 2c front pipe to fit? Not sure if that is any easier or more available, just a thought.
Re: 125H/Corsaro
Morini 125cc Corsaro exhaust downpipe.
Flange O.D. - 37.5mm.
Flange thickness - 2.0mm.
Pipe O.D. - 32mm.
Pipe I.D. - 28.5mm.
If you need to get one made, Den Tietze of Alldens in Market Rasen has a good reputation.
It sounds as though he would welcome the business...
https://www.gofundme.com/f/help-to-prevent-closure
125H
Re: 125H/Corsaro
Post by 125H »
Hi Jenny,
thanks for your reply and the measurements, from those it would not fit a 125H as you suggest. Armours can make me a pipe for around £200 or I will try Alldens although I did ask him to make a megaphone some years ago and he was too bust at that time. But maybe things have changed.
The reason I asked about a Corsaro exhaust was that there are several on eBay but none for a 125H, its always the case as there were some on there a few weeks ago. Its possible to pick up a complete engine or a frame, but exhausts only last perhaps 15 to 20 years so no wonder they are disappearing and buying a used one unless its new old stock would probably just compound the problem, a new pipe may be the best option, if it fits!
Best regards
Leonard.
125H
Re: 125H/Corsaro
Post by 125H »
I tried a 350 pipe but the exhaust nut would not pass the first bend for some reason, I may look around for a 250 twin pipe or a 250 single pipe all options a re open!
Leonard.
davel182
Re: 125H/Corsaro
Post by davel182 »
A 250 single pipe will not fit - they are 35mm (that's if you could find one!).
125H
Re: 125H/Corsaro
Post by 125H »
Hi all,
thanks for the input, I have had the perforated section cut out and replaced with new pipe and welded in place, cannot see the join and the job is very neat, when its polished and triple plated again I'm sure it will look like new.
Leonard.
Re: 125H/Corsaro
Sounds like a good result. Who did the work? Was it a professional company or just someone you heard of?
125H
Re: 125H/Corsaro
Post by 125H »
Hi Jen,
the work was done by a company called welding capacity, based in Silbey near Loughborough.
They made a neat job of the join, in fact I cannot not see the join, but I had to dress the pipe after with abrasive cloth
the chrome platers would have done that, but the more they do the more they charge and plating prices are going through the roof.
Re: 125H/Corsaro
Post by julianharty »
125H wrote: 28 Mar 2025 17:16 does anyone know if a Corsaro exhaust pipe would fit a 125H/
New copies of the silencer for the 125H are available from two vendors in Italy. Here are the current links: You'll notice their prices are substantially different. From memory when I saw them at a recent Novegro Scambio near Milan the quality of the two suppliers also varies substantially. There are also very rare private adverts in Europe that list the silencer or the downpipe. From memory the original silencer has the part number 6768 which is how I spot the infrequent listings. Good luck.
PS: For my 125H project I bought a used 32mm diameter silencer intended for a Moto Guzzi for £10 as an inexpensive stand-in. I'd be tempted to buy one of the next silencers if I finally complete the project and enjoy riding the 125H (actually it's the later 125 T, an H with fibreglass bodywork).
125H
Re: 125H/Corsaro
Post by 125H »
Hello Julian,
sorry for my tardy response, I have had the header pipe welded and rechromed along with the non - standard 'silencer' and it all looks the part again.
Thanks for your response
Leonard.
