The battery is past it's best on mine, but given that it starts so easily on the kicker I have decided to remove the leccy starter.
Also means that I fit a lighter lower capacity battery.
Makes sense to me.
Starter will be put into storage until the time comes to sell the bike.
Electric Start
Electric Start
Re: Electric Start
Or you stall it in gear in a queue and realise you can't find neutral...
Re: Electric Start
Pushing the bike about 30 cm forwards while trying to find the neutral normaly will enterMickeyMoto wrote: ↑17 Mar 2025 19:05 Or you stall it in gear in a queue and realise you can't find neutral...![]()
Re: Electric Start
Well I never did remove the starter, decided it was too useful so bought a new battery - Yuasa YT12B-BS which is good enough ?
Roll on a few months, it has decided it no longer wants to start on the leccy start. It still starts first or second kick, but flatly refuses to fire on the starter.
A few weeks ago I took the motor apart and cleaned it up and for a while it would start on the electric starter, it seems like the motor just does not turn it over fast enough, I have checked the motor leads and earth leads for high resistance, and it all checks out as well under 1 ohm as far as my test meter tells me.
Battery voltage is just over 13 volts with no load, so I am guessing that the motor is past it's best, perhaps the time has come to remove the leccy start after all.
Re: Electric Start
Have found so far that a vertex vp2op-3-1 works my starter ok
steve
steve
