Clutch centre difference
Please see my reply on the seized nuts post in the 350 forum. I am guilty of spreading the rumour that the clutch centre hub is the same on both.
Well it isn't. You probably know already, sorry if I have mislead anyone.
Re: Clutch centre difference
Are you sure?
I thought the difference was the input shaft on the 500 is beefier and the sleeve is different, but the hub is the same.
Referee!
MickeyMoto wrote: 21 Nov 2023 21:13 Are you sure?
Referee!
Oops, just seen your other post.
How would the plates be the same if the centre hubs were different?
MickeyMoto wrote: 21 Nov 2023 21:19
Referee!
Steve Brown wrote: 21 Nov 2023 23:46
Referee!
It's just the diameter of the inner splined part.(where it fits on the gearbox mainshaft) That is a half a tad grosserer in a daimetrical sort of way. Ish. The rest is the same hence no trouble swapping plates. I can't believe I got away with it so long.
Yes, I worked it out in bed last night. Instead of dreaming of Kylie Minogue, I dream of Morini clutch centres!
Good to have it confirmed.
