WANTED - Camel Mk2 front upper chain rubbing block.
Kamel
Post by Kamel »
Camel Mk2 front upper chain rubbing block wanted or dimensions / pictures of the same so I can reproduce one.
Kamel.
hombre
Re: WANTED - Camel Mk2 front upper chain rubbing block.
Post by hombre »
The one on the rear fork you mean? In Italy some guy is reproducing them, https://www.morinispecial.it/forum/Merc ... l?start=32
The ebay item Ian mentioned looks a lot like the one I used on mine. I got mine from Inmotion trials, it was meant for a Bultaco and cost about the same.
Kamel
Post by Kamel »
Thanks both, I’ll take a look.
Cheers.
Kamel
Post by Kamel »
Hi all,
I ordered the eBay one, and although I was dreading fitting it, it went in quite easily once I "persuaded" the outer bracket a bit further out.
https://www.ebay.co.uk/itm/165430311819 ... 5430311819
Thanks to all for the help.
Kamel.
