Speedometer Cable Outer
jb666
Post by jb666 »
Has anyone got a speedo cable outer that they are willing to part with? I went to put the speedo cable back on the Strada and found that somehow the outer casing had got stretched so when it is flexed the inner drive cable didn't engage with the speedo.
John.
Re: Speedometer Cable Outer
Hi John
If no luck maybe try making one https://www.carrotcycles.co.uk/speedo-t ... fting.html
All the best
AntietamClassicCycle
Another instance where a Guzzi part may work. The "small-block" Guzzis (V35, V50, V65) use a cable with the same end fittings, however length may be different.
huub
Post by huub »
TLM.nl quotes the exact length of the guzzi speedo cables in their webshop,
so you should be able to find which one fits.
