Sugar cube fuel tap for 3.5
Lewes96
Post by Lewes96 »
If anyone has a spare one.Cheers
FatherB
Re: Sugar cube fuel tap for 3.5
Post by FatherB »
Try Officine08.com They have loads of taps on there.
Post by simonnorthroad »
Found taps on he Officine08 website with some difficulty. It hasn't got this kind of tap you want. Don't bother
Lewes96
Post by Lewes96 »
Thanks for the tip but had a quick check and sure enough none there.
Gutsibits has them occasionally and HMB Guzzi in Germany but the latters' postal costs make them.expensive
https://www.ebay.co.uk/itm/351981103822 ... SwRWddxul6
You may wish to check it is the correct size...
Have you tried discovolante , common to some Ducatis I think.
BumbleBee
Post by BumbleBee »
Apologies if you already decided against, but a popular option is to replace it with a manual tap from a V50 Guzzi and gain the advantages, or even to do both taps like this.
G&A
BumbleBee wrote: 07 May 2021 10:18 Apologies if you already decided against, but a popular option is to replace it with a manual tap from a V50 Guzzi and gain the advantages, or even to do both taps like this.
G&A
Exactly as I have done, use a V50 etc tap available from Gutsibits about 1/3 price of a Paioli tap , also has reserve if you want.
I use it as the main tap and the electro tap just stops the fuel leaking out of the tank.
