K2 no carb balance take off points
Brickboy
Post by Brickboy »
I have come across a bit of a quandary. I have a lovely Carbtune, and plenty of adaptors, including for those funny holes on the Strada where you pull out the metal plugs.
But, on my K2 I see no entry point! Two bosses on the intake rubbers that look like they are designed for an entry point but they are blank.
Now, this is a great Morini challenge... Is there an answer before I get the drill out?
Simon
Re: K2 no carb balance take off points
Hi, like the 500s they have a balance pipe between the carbs?
Pull this off and connect up your Carbtune pipes here.
Have fun, Ian
Brickboy
Post by Brickboy »
Ah... Yes thank you 🙂
Paz2112
Post by Paz2112 »
In the case you don't have any balancing pipe, how do people get connected to the carb. Do I still the boss in the rubber intake rubber?
Yes, you then need the barbed inserts, together with plugs / caps for them.
Paz2112
Post by Paz2112 »
Thank you. Is there a link or place I can order the barbs?
Brickboy
Post by Brickboy »
I did have take off points and I now have a sweet, smooth engine and a 1250rpm tickover. Wonderful.
