Muffler putty
rossguzzi
Muffler putty
Post by rossguzzi »
Is there a type of muffler putty that could be used to help seal header pipe to head ? I'm using a proper gasket but I would like to aid sealing using some sort of putty.
Any suggestions ?
Re: Muffler putty
Don't do it! If you can't get a proper seal with collets and joint, you have a problem somewhere. It can take a bit of adjustment to get both ends of the pipe to fit their respective orifices, persevere a bit.
rossguzzi
Re: Muffler putty
Post by rossguzzi »
There are no collets. Just screw nut a up to a flange. Gasket between flange and head. I'm tempted to use 2 gaskets.
Re: Muffler putty
Post by simonnorthroad »
Yes why not use 2 if you have to, just don't start introducing gunk into the port/threads.
You could even use a compressible gasket and a copper ring, of which there are many of all diameters on Fleabay
