Brake Bleed Nipple
Pilbeam1
Brake Bleed Nipple
Post by Pilbeam1 »
I need to replace the brake bleed nipple in the Grimeca front caliper.
Where can I buy the original type that includes a ball?
Or can I use a conventional one with a taper seat?
Re: Brake Bleed Nipple
Post by simonnorthroad »
Ive done the latter before now and dispensed with the ball-bearing.
Ive also spent days trying to bleed a Grimeca caliper before I discovered there was a ball-bearing blocking the passage....reverse bleeding with a syringe was messy
Having a steel bleed nipple bear directly on the seat can tear them up badly over time. Having access to a lathe, I modify standard nipples.
Pilbeam1
Post by Pilbeam1 »
Paul,
That's interesting.
Do you modify the bleed nipple to accommodate the ball bearing?
If that is true what diameter ball bearing do you use?
