Hello as stated above a silly one, I have a kanguro 350 x 1983
I bought it as a non runner, she is now running, so I am on to electrics, I have put in a new 6 volt battery, and need to replace the headlight bulb and instrument lights. When I took the old headlight bulb out it said 12v 35w, is this right ? and as for those little push in jobs no markings at all should they be 12v or 6v ?
oh and one other thing I have found no fuses anywhere ! despite every wiring diagram I have looked at telling me there should be a fuse box. Ok so am I being really dumb ? Help me if you can please thanks Simon.
350 ...bit of a daft question about bulbs
sikadellic
]It is NEVER too late for a happy childhood.
Re: 350 ...bit of a daft question about bulbs
The X3 went to all 12v due to the electric starter.
David
Hi, early kick start only Kanguros and Camels had a 6V DC/12 AC system.
The alternator stator and regulator supplies 12V AC to the headlight and a DC supply to charge the 6V battery from which all other lights and the horn get their power.
So everything is 6V except the 12V headlight bulb.
Trust this helps
Trust this helps
sikadellic
Fantastic information thank you very much.
