ECU MAP : TUNE ECU
rrey
ECU MAP : TUNE ECU
Post by rrey »
Hello again,
Tune ECU is free software to tune european bikes. We have used it many times for KTM and Triumph dyno tuning in the shop. For MotoMorini seems to be available through Android. Has anybody used it or got his bike remapped ?,
eddydog
Re: ECU MAP : TUNE ECU
Post by eddydog »
Hi. Yes. I did it. Need to buy a programs from Google Play and to buy a wire.Summer was finished and i tryed to remap my ECU on Corsaro 1200. Everything worked out. Successfully.
alfa
Post by alfa »
eddydog wrote:Hi. Yes. I did it. Need to buy a programs from Google Play and to buy a wire.Summer was finished and i tryed to remap my ECU on Corsaro 1200. Everything worked out. Successfully.
Hi!
can your get me some detail about this process?
I plan to do it in March (granpasso)
I have Tune ECU lite which is used on a Triumph with OBDII Bluetooth plug. The Tuneecu site has some Morini maps.
The Morini uses a different plug. I tried a company that said it supplied the cable but they have failed to return my calls.
Does anybody know another source for the cable, please?
alfa
Post by alfa »
I bought a cable here (but did not use it yet):
https://www.ebay.com/itm/201997582189?u ... noapp=true
rrey
Post by rrey »
Here you have it after TuneECU tuning.
https://www.youtube.com/watch?v=j2pxGIdIvCI
Mileage greatly improved and the 3000-3500rpm empty spot solved. Map matched to the dual sport exhausts. Works great indeed.
roofus
Post by roofus »
nice 1 ,is that with the cat in ?and safe on a dyno
i used tune ecu dowloaded map from tune ecu bike was un rideable and reset the mileage to zero :(
