robinh44 wrote:Hi,
The coil measuring 220ohm will be the ignition coil, your 6v/12v coils should measure approx 0.8-1.0 ohm. On the 6v/12v bikes the grey wire from your alternator will carry the 12v volt. With the bike running measure or connect a 12v bulb and see if you get a good output. If you do I suspect it is a poor connection somewhere between the headlight and the coil as the coil directly feeds 12vac unregulated or rectified to the headlight.
Robin
Hi robin, thanks for the reply
today in the afternoon i will look for some poor connection around the bike
at the momenti have a little bit different setup that the original morini loom
i'm running only on 12volt, without battery for the front and rear light always powered on from more than one year but at the time that i do this "mod" i needed to install a 12v 9ah-max rectifier from a piaggio vespa because when the engine is revved over 3.000rpm every kind of light is burned...
on
www.motomoriniclub.nl i read this:
"Between the metal mass of the generator
and green wire you should measure something
between 170 and 250 Ohm. In that case the
yellow ignition coil is OK."
but if you take a look on
www.morinispecial.it you can read that a good value is 300ohm, much more than what is stated on moriniclub.nl
so which measurement is good?
i hope that all that info maybe usefoul
thanks
