Have any owners out there reinforced the bodywork panels? Mine has some repairs but the original plastic is now so brittle I am thinking of reinforcing all the edges especially around the fastener holes before they snap so I don't lose the bits if it happens on the road.
I suppose the dream would be carbon fibre but I should think a fine weave glass fibre would do the trick as it is mostly unseen and if one decides not to get too stressed over adding a couple of kg to the weight of the bike.
Body panels
- Contact:
Re: Body panels
The big problem is getting any kind of bond to the vaccum formed plastic.
The plastex repair system will bond and you can use it to encapsulate reinforcement; http://www.repairproducts.co.uk/page20.htm
Also see; viewtopic.php?f=16&t=2517&p=12428&hilit ... els#p12428
HC Racecraft don't seem to be around any more, but try Olaf.
