Key made for 1974 350S
fcnomad
Post by fcnomad »
Hi all,
I am the proud new father of a beautiful 1974 3 1/2 sport. She runs and needs but a tuneup to be at her best. The bike came with only one old CEV key (no numbers on it). I have been to several locksmiths to try to get duplicates made. No luck so far. Does anyone have any info on key blank sources or codes I can use in my quest?
Many thanks!
'74 350 Sport
'79 350 Strada
fcnomad
Van883
Post by Van883 »
North Leicester Motorcycles supplied me with a blank key last year.
cheers
Van
fcnomad
Post by fcnomad »
Thanks Van,
I will give them a ring since it seems that all roads eventually lead to NLM for MMs.
'74 350 Sport
'79 350 Strada
fcnomad
robinh44
Post by robinh44 »
Nomad
My local key cutting shop used a blank from an Alfa Romeo, not sure which model. I needed a slightly longer key and he found the Alfa Romeo blank was up to the job. My morini is a 84 kanguro so not sure if the ignition switches have changed much.
Robin
I got a second hand loom a few months ago with a better ignition switch but no key.I gave NLM the number from the front plate of the switch and a key was obtained. Then I got spares cut from it locally.What number is on yours?
fcnomad
Post by fcnomad »
Thank you all for your suggestions! I just found a Morini enthusiast here in Brooklyn, NY (seems rare indeed) who has a locksmith with access to all sorts of old and discontinued keys including Guzzies, Dukes etc... Not cheap but worth the price if all else fails.
'74 350 Sport
'79 350 Strada
fcnomad
