LSR Running Oil Pressure ???
smotorboy
Post by smotorboy »
Hello All,
I have my motor apart and am cleaning and checking thing over.
I see in the Service Manual about cleaning and checking the oil pressure relief valve but there is no information about what the running oil pressure range should be.
Could someone please tell me the pressure that they have seen on a gauge when the motor is at normal operating temperature.
I have a gauge that I will fit on the motor as it is needed after seeing first hand how the oiling system is laid out...
Robert in California
smotorboy
Re: LSR Running Oil Pressure ???
Post by smotorboy »
The relief valve is set at 60 psi.....
I'm getting all my gauges in and working right now and I can now see the oil pressure and temperature,,,,
El Mirage's July event was canceled, but I'm going to the desert for private test runs later in the week...
