Hi all.
Looking for a replacement small end/little end bush/bearing for a Corsaro 125 single,I'll try NLM on tuesday when open,the bush being the source of the rattling on my Benelli/Morini hybrid,any help or direction appreciated!
Thanks Dave.
Corsaro 125 Connecting rod little end bearing/bush.
morini500dave
- George 350
Re: Corsaro 125 Connecting rod little end bearing/bush.
Sorry but cant help with the bush, but NLM are open on Mondays now as well. If no luck with them then you need to know the piston pin diameter and the outer diameter. You may be lucky and find that it is a standard bush available from bearing suppliers. If it is unique, a machine shop should be able to turn one up for you from a piece of phosphor bronze.
Good Luck in your search.
George.
George.
I do not know if we already corresponded by e-mail before. Ib any case, I have the small end bushes for the Corsaro 125 but not for the Corsaro 150.
Pls confirm if you need one or more than one.
alexluzzi@gmail.com
Best regards
alexluzzi@gmail.com
Best regards
