I need a left hand drive headlight unit for my Camel, the one I have is R/hand.
Thanks.
Camel 501 headlight unit LHD
Singer 185K
Wheel Horse commando 7
Honda SS90 1965
Honda SS90 1965
Re: Camel 501 headlight unit LHD
Hi, if it's the P45t Asymmetric type bulb all you do is rotate the bulb in the mounting by cutting/filing a new locating notch in the reflector mount.
Look at the bulb first (inside) as the filament shield/reflector gives the dip cut off and work out the rotation, it's only a few degrees.
I've done it to 501 & 500 Camels, 500 5 speed, Citroen and Renault cars.
Hope this helps ?
Hope this helps ?
And there was me thinking it was mostly down to the lens! Maybe it is in later types of headlamp...
Nick
Nick
