Slotted Screwdriver
steve pegg
Slotted Screwdriver
Post by steve pegg »
Gentlemen and Others,
Has anyone got a slotted screwdriver I could buy or borrow so I can dis assemble my clutch. I am in the south east.
Thanks, Steve
Re: Slotted Screwdriver
Steve I made a suitable tool by cutting a v-shaped slot into a piece of flat steel with a hacksaw.Then I turn it with an ajustable spanner.Crude I know.What else to do in this weather?
hendre
Post by hendre »
I just bought a huge screwdriver (at a place where they sell tractor suplies) at €15 euros and took a dremel tool to cut out the centre bit... works like a charm already for years :mrgreen:
steve pegg
Thanks Guys,
I have undone a few clutches but this one is really screwed up TIGHT. I had not thought of the tractor shop option so will go for the tool steel solution/Big screwdriver and yes the weather is special!!
steve pegg wrote:Thanks Guys,
Use penetrating fluid (ATF and Acetone is about as good as anything) and some heat first. The studs can break loose from the drum!
I have a bit of hex bar stock with the slotted drive in the end. You can use it with a spanner or a socket.
WeeVee hex head clutch screws on mine make life much easier. :)
MarkB
Post by MarkB »
Steve, if you still need the slotted screwdriver, PM me your address.
Cheers, Mark.
"I'll have a V please, Bob."
