Throttle - cables pop out
I suppose this applies to 31/2 too.
Has anybody had problems with cables coming out of the handlebar end of the throttle? I see the barrel goes around so far that the cables pop out. I have put a piece of plastic in the bottom and this prevents the barrel going too far back, unfortunately, the throttle no longer returns on it's own. It isn't a problem, unless I fall off, (a cheap cruise control, like the old friction screws!) but I wonder if there should be some sort of stop to prevent the barrel going back too far?
Thanks,
Mike
Re: Throttle - cables pop out
Problem solved- it needs a bolt in a pre drilled hole. There was a piece of plastic to prevent the barrel going too far but obviously broken.
