I know it has a flywheel alternator with six windings one of which powers the ignition ( green wire). What I want to know is how are the other 5 windings connected to produce the two field wires (yellow)? Is it a single phase alternator or a three phase? What is the red wire connected between the alternator and battery positive for?
In the case of the regulator I can see the yellow field wires connect to 2 diodes inside the aluminium box and then appear to go into a sealed unit. How is voltage control achieved? Does the sealed unit control the voltage to the battery via the brown wire? Is the sealed unit a sort of zennor diode? In books I have read full wave rectification needs 4 diodes so why only 2on the Morini?
I know I know it's a lot of questions. Sadly I worry about these things
any ideas much appreciated
Cliff
