fork tube replacement
Hi all, new Morini owner here in the states and I need to replace the fork tubes on my 500 sei. That is proving difficult as Morinis are rare as rocking horse poo here. Can anyone suggest a source or provide info on an alternative?
I know they are 35mm which is common and Honda CBs and Suzuki GSs used the same size, but....
thanks
thanks
Re: fork tube replacement
Follow up questions: Will the forks from a 250 work? What other Morini forks are interchangeable? thanks.
The 250 forks are a smaller diameter.
Disco Volante sell new forks I think.
http://www.discovolantemoto.co.uk/index.php
The 250 (single and twin) use Paoli forks and they're 1 1/4" diameter (31.75mm).
350 and 500 stanchions are the same (early 350 are 10mm longer) and Discovolante are probably the best source. They're not much more than re-chroming and grinding.
Ducati Pantah fork tubes are identical to the Morini 500.
Bruno
Bruno
Thanks for the info. I'll check out discovolante ASAP.
The tip on the Pantah forks is handy, but they ain't too common round here neither!
I just got an updated price from DiscoVolante.
It came to £148.50 plus postage (£10) and VAT.
Fast from the Past is the U.S Tarozzi guy. Very easy to deal with and will save you a bunch in shipping.
http://www.fastfromthepast.com/servlet/ ... Categories
Regards,
Mathew
Regards,
Mathew
MRC #2795
Hey all, just a quick follow up. I wound up having new forks made by Forking by Frank. Not at all expensive and outstanding results! Now on to the dodgy electrics and the shagged starter....
John Bunting
Henry, everybody has a shagged starter, usually stored under a workshop bench, get kicking.henrymski wrote:Hey all, just a quick follow up. I wound up having new forks made by Forking by Frank. Not at all expensive and outstanding results! Now on to the dodgy electrics and the shagged starter....
Good to hear your forks are sorted.
