ecu and tps
twisty
ecu and tps
Post by twisty »
If the ecu is swapped ,does the tps need to be reset each time, or can they be swapped willy nilly :?:
vtxbrit
Re: ecu and tps
Post by vtxbrit »
My understanding (according to Richard of the late tecmoto) is that every time you remove the ecu the TPs needs to be reset, seems crazy to me…………. And the tool to do it is a fortune.
I have a pcIII for my Veloce but have never put it on, the pcIII has the facility to reset the TPS so maybe fitting one would be a cost effective way to enable TPS resetting.
I know there is some downloadable software for the Morini ECU but I am not sure what it allows you to do, maybe you could fire an email to Alex (Maniac Motors) he is extremely knowledgeable with Morini’s and Benelli’s.
vtxbrit
Corsaro Veloce
Aprilia TuonoV4 APRC
4V 500 Weslake Barber grass tracker
2V 500 Jawa Hagon grasstracker
500 Jap 4B Barber grasstracker
500 Jap 5stud jawa speedway
