I'm here on the other side of the world from NLM with my new progressive fork springs, and I have some questions. I should call them, but they're not up yet and some of you probably are.
First, it's a 1983 K Sport with Marzocchi forks. The old springs are 46cm long, with a metal sheath 25cm long over the top half and above that is an 8.5cm spacer. (Total length, 54.5cm.) The new springs are 54cm long and appreciably wider, so the sheath does not fit and is therefore - I presume - out of the picture. Here's the tricky part (to me).
If I use the 8.5cm spacer, I cannot physically compress the springs enough to get the nut into the threads. Without the spacer the new springs fit almost to the bottom of the nut and once tightened, everything feels pretty slack. The lack of tension/general springiness when pushing down on the handlebars tells me I may need the spacer, making my effective spring length 62.5cm, so what's the trick?
DD
