Page 2 of 2
Re: Chain and sprockets
Posted: 07 Aug 2025 22:15
by norbert
The diameter of the 6 holes for the bolts in these 6 hole sprocket supplied by Dieter are 1 mm minor than what we need to fix the sprocket to the spocket carrier of the Strada. You have to drill them 1 mm wider (if I remember it well).
Posted: 08 Aug 2025 08:12
by rossguzzi
Ahh, thanks. Wasnt sure if you meant the centre hole.
Cheers.
Posted: 29 Aug 2025 10:50
by jcmarcos
norbert wrote: 07 Aug 2025 22:15
Amazingly, the 36 tooth sprocket that MJCorse made for my Dart has exactly the same problem. It's made in duraluminium, so it might be easier to enlarge them with a round file... I say "might" because I didn't do it, and bolted it immediately on the wheel, having a heck of a tough time and, hopefully not, an abuse of the wheel threads
Posted: 29 Aug 2025 10:57
by jcmarcos
rossguzzi wrote: 03 Aug 2025 23:59
Mdina stock 38, but I dont see 39. Where in Spain did you get your 39 ?
Alicante based MJCorse did a 36 for my Dart:
https://mjcorse.com/es/corona-mj-a-medida.html
Easy because they make sprockets for Cagiva Freccia, from 36 up to an stupid 54
https://mjcorse.com/es/corona-pinon/cor ... 87-92.html
