Would anyone have a spare PHBH 26BS carb or two they would sell? Or some parts from one - float bowl, top cover, slides, fuel banjo
Thank you,
Fiona
Sydney, Australia
phbh 26bs carb for 500cc 5 speed
Re: phbh 26bs carb for 500cc 5 speed
Hi Fiona ,
All the parts you require are still available,
Please see link
https://www.dellorto.co.uk/product-cate ... phb-parts/
Rick
Please see link
Rick
Thank you Rick! I did notice some new entire PHBH 26BS carbs still sold by Dellorto but I wasn't sure if they were exactly the same as it looked like they were listed for racing or 2 strokes.Would you know if they are correct for the old Morini? If so it may be easiest if I buy new ones
Fiona. Sydney Australia
I found eurocarb very knowledgeable and helpful. Try emailing Robert rob@dellorto.co.uk for advice
Best of luck
Best of luck
Hi Fiona,
Hope all's well
I have certainly got a floatbowl,
The early carb tops were metal, then yellow(ish) plastic then black. What colour do you need? I may have the correct one
Probably got a twin outlet fuel banjo
MAYBE a slide, depending on the number/cutaway
All cheap. Slides are weirdly expensive new...
Will have to be 'creative' with the Customs label to get past our and your neurotic Postal service and onto a plane too....
Can you PM me? moriniboy23@yahoo.co.uk
Simon
Hope all's well
Simon
Thank you for the really helpful replies! I have emailed you Simon. It also looks like the entire carbs are still made by Dellorto to my amazement. Although advertised on some sites as being for two strokes and racebikes , the US Dellorto dealer who used to be a Morini dealer has said he could set up a pair of new ones for me for Morini 500W, should I go down that path.
Much appreciated as always,
Fiona
Fiona
Havent received any email from you Fiona. Usual reason is some typo in the email address. You can Whatsapp me? +44 7788 442155park3164 wrote: ↑16 Aug 2025 05:37 Thank you for the really helpful replies! I have emailed you Simon. It also looks like the entire carbs are still made by Dellorto to my amazement. Although advertised on some sites as being for two strokes and racebikes , the US Dellorto dealer who used to be a Morini dealer has said he could set up a pair of new ones for me for Morini 500W, should I go down that path.
Fiona
Hi Simon ,
I have PM'd you via this forum now. Hope you get it this time.
Fiona
Fiona
