Rear light wiring??
Maestro, SEI-V
Dickyboy
Rear light wiring??
Post by Dickyboy »
So the brake light works fine, the side lights work fine and the headlight works fine but the tail light only works with side lights & not with the headlight, which is rather odd. Any ideas what I should start looking at?
Re: Rear light wiring??
A question. When the taillight goes out, does the pilot light in the headlamp also go out?
If it does then the fault is likely to be within the handlebar switch - the off/pilot/headlamp one.
ie, when the switch is moved from pilot to full headlamp, it is disconnecting the power from the pilot/tail circuit.
If it is just the tail lamp, then the fault must be in the wiring/ connections. Eg. Are the 3 wires on the tail light unit connected correctly?
Hope this helps,
Have you got the original ignition switch? Can you turn it one more turn. Reason I ask is that I fitted a non standard one to replace a faulty original and there is an extra position.
The first turn activates all circuits except tail. Second position - full lighting. A bit of a nuisance but am used to it.
Dickyboy
Post by Dickyboy »
Thanks, I'll take a bit more of a look and report back later.
Dickyboy
Post by Dickyboy »
Well that was pretty simple, John had it in one, the ignition switch has a second location & all lighting works, amazing, now to get to work on the odometer trip reset....
TimClarke
Post by TimClarke »
Dickyboy wrote: 09 Mar 2025 14:54 Well that was pretty simple, John had it in one, the ignition switch has a second location & all lighting works, amazing, now to get to work on the odometer trip reset....
Let me know how/if you sort the trip meter!
Dickyboy
Post by Dickyboy »
TimClarke wrote: 09 Mar 2025 18:22
Tim, yes trip meter sorted, disconnected Speedo drive and lights, then top nut around trip meter knob so I could remove clocks & cable in one piece, checked trip reset actually worked & then oiled & wiggled cable quite a bit as it kind of gets frozen in one position then refitted - the knob works anti clockwise & requires a decent force to turn it now but it does work 👍
TimClarke
Post by TimClarke »
Dickyboy wrote: 11 Mar 2025 07:50
Ah well done - thanks for the tips as well I shall have a go at it in the morning!
