Shop full of Spares. Stock from closed dealer in Barcelona
Re: Shop full of Spares. Stock from closed dealer in Barcelona
Thank you Ian. I might get back to you but would prefer black if possible.
In amongst the tanks that you had you don't have one from a late model 501 Camel do you? The larger tank, Paris Dakar style.
Hi, Sorry fork gaiters only in Red! Only 501 tank I have is on a 501! It is for sale though. Whole bike, not just tank!
Cheers Ian
Cheers Ian
Thanks Ian one is enough for now thank you!
HI Ian
i need a crank for that has ball bearing on both sides and 2 sport pistons and 1 conrods
Hi i own a 1976 morini 3 1/2 sport wire wheels disc brake front,
hi Ian
the crank i need is in the morini green 3 1/2 parts book item number 12.04.01 page 1.002
hi Ian
my engine is with Benjy HE CAN'T FIX IT FOR A COUPLE OF MONTHS SO I AM NOT DESPERATE FOR THE CRANK SHAFT YET
REGARDS MIKE
REGARDS MIKE
Hi Mike,
No problem, talking to Benjy. Do you ever read your Personal Messages on the Forum. I have sent you a couple but they appear to be unopened. You were asking about brake shoes a year or so ago. Do you still need some? Thanks Ian
Hi Simon
Benjy is doing the rebuild and I have sorted the bits for him but thanks for the offer
Cheers Ian
Cheers Ian
Hi Simon
Cheers Ian
Cheers Ian
Hello Again Ian,
Do you have any exhaust Collets / Split rings for a 501 Camel? On pulling mine apart they are missing from one exhaust. The shouldered split ring that sit in the exhaust port.
Mdina are hoping to gett some made but no timeframe as yet.
Hello Will check. I have lots for 3 1/2 (and they are not all the same either) but not sure about the bigger ones. I do at least know where they are!
Hi Ian,
Do you have the kickstarter mechanism for a 250h or a 500. I believe the starter gear will be a larger diameter and possibly have more teeth than a 350.
I would also be interested in any spares you have suitable for a 125kj or 250h.
Many thanks,
Norton
Many thanks,
Norton
Hello I have checked and have most different types of 350 collets but no 500 ones. Sorry
I will go and check kickstarts now. I can also do a list of (mainly KJ) bits I have. Do you want to PM me your number as I can then send pictures by WhatsApp assuming you use that. Thanks Ian
